FreeRTOS MPS2 QEMU Demo (Arm Cortex-M3)
For both the IAR and arm-none-eabi-gcc compilers (makefile and Eclipse)
This page documents a FreeRTOS kernel demo that targets the Arm Cortex-M3
mps2-an385 QEMU model. Preconfigured
build projects are provided for both the
IAR Embedded Workbench and
arm-none-eabi-gcc (GNU GCC) compilers. The GCC project uses a simple makefile that can be built from the command line or the provided
Eclipse CDT IDE project.
IMPORTANT! Notes on using the QEMU Cortex-M3 RTOS demo
- Source Code Organisation
- The Demo Application
See also the FAQ
My application does not run, what could be wrong?,
noting in particular the recommendation to develop with
configASSERT() defined
in
FreeRTOSConfig.h and
configCHECK_FOR_STACK_OVERFLOW
set to 2.
The FreeRTOS distribution available from this website site contains the source files for all the FreeRTOS
ports, and the projects for all the FreeRTOS demo applications. It therefore contains many
more files than are required to use the Cortex-M3 mps2-an385 QEMU demo.
section for a description of the directory structure and information on creating a
new FreeRTOS project.
The IAR Embedded Workbench for ARM workspace for the mps2-an385 demo application is called
RTOSDemo.eww, and is located in the FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/iar
directory.
The makefile that builds the project using the arm-none-eabi-gcc (GNU GCC) compiler, and
the Eclipse project that builds the same makefile, are both located in the
FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/gcc directory.
The mps2-an385 Arm Cortex-M3 QEMU Demo Application
The demo projects provide both the simple blinky and comprehensive test/demo
configurations described on the
FreeRTOS Demos Applications
documentation page. Specific to the demo documented on this page, the "check"
task periodically prints a message in the following format:
StatusMessageString : aaaa (bb)
Where StatusMessageString is a descriptive text string, aaaa is the RTOS tick
count, and bb is the number of times the application detected interrupts becoming
nested.
Open FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/iar/RTOSDemo.eww
from within the IAR Embedded Workbench IDE.
Open main.c, and set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to generate either
the simply blinky demo, or the comprehensive test and demo application, as
required.
Select 'Rebuild All' from the IDE's 'Project' menu, the
RTOS Demo project should build without any errors or warnings. A successful build
creates the elf file FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/iar/Debug/Exe/RTOSDemo.out.
Note: If QEMU is already running the build will fail because QEMU prevents the generated elf file from being overwritten.
Ensure QEMU is installed on your host computer.
Start QEMU with the following command line, replacing [path-to] with
the correct path to the RTOSDemo.out file generated by the IAR build.
qemu-system-arm -machine mps2-an385 -cpu cortex-m3 -kernel [path-to]/RTOSDemo.out -monitor none -nographic -serial stdio -s -S
QEMU command line
Omit the "-s -S" if you just
want to run the FreeRTOS application in QEMU without attaching the
debugger.
After the build completes, select 'Download and Debug' from the IDE's 'Project'
menu. The IAR debugger should create a GDB connection to QEMU, start a debug
session, and break on entry to the main() function.Note: Remember to kill the QEMU session when the debugging
session ends, otherwise QEMU will prevent the executable image being
overwritten the next time the IAR project is built - resulting in a
linker error.
Building and executing the demo application - GCC Makefile
Ensure both the
arm-none-eabi-gcc compiler and GNU make utility are installed
on your host machine.
Open FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/main.c, and set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to generate either
required.
Open a command prompt and navigate to the FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/gcc
directory.
Type "make" in the command prompt. The project should build without any
compiler errors or warnings. Hint: Use the "-j" parameter to
speed the compilation by using more cores on your host computer. For example,
if you have four cores available you can build four C files at once by
entering "make -j4". A successful build
creates the elf file FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/gcc/output/RTOSDemo.out.
the correct path to the RTOSDemo.out file generated by the GCC build.
QEMU command line
debugger.
You can now use arm-none-eabi-gdb to start a command line debug session following below steps,
although my preference is to start a graphical debug session, as described
next for those using the Eclipse IDE.
- Start GDB: navigate to the path to RTOSDemo.out, and start ‘arm-none-eabi-gdb’.
arm-none-eabi-gdb RTOSDemo.out
- Connect to QEMU: the default port for QEMU is 1234.
(gdb) target remote localhost:1234
- Set breakpoints.
(gdb) break main
- Start debugging.
(gdb) continue
- Quit GDB.
(gdb) quit
Building and executing the demo application - Eclipse
Ensure the
arm-none-eabi-gcc compiler and Eclipse CDT IDE are installed
on your host machine. It may be necessary to install the GNU make utility separately if it is not included with Eclipse.
Select 'Import' from the Eclipse 'File'
menu, then 'Existing Projects Into Workspace' in the resultant window before clicking the Next button.
In the next Window, select /FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/build/gcc
as the root directory, check the FreeRTOSDemo project, and
crucially ensure the "Copy projects into workspace" checkbox is unchecked, before clicking the Finish button to bring the project into
Eclipse.
required.
Select 'Build All' from the Eclipse 'Project' menu. A successful build
Open a command prompt then start QEMU with the following command line,
QEMU command line
debugger.
Click the little arrow next to the green bug speed button, then select "Debug Configurations..." from the resultant menu.
In the debug configurations window, select "FreeRTOSDemo Default" from under "GDB Hardware Debugging", then
click the Debug button. The Eclipse debugger should create a GDB connection to QEMU, start a debug
ARM Cortex-M3 RTOS port specific configuration
Configuration items specific to this demo are contained in
FreeRTOS/Demo/CORTEX_MPS2_QEMU_IAR_GCC/FreeRTOSConfig.h.
The constants defined in this file can be edited to suit your application.
In particular -
configTICK_RATE_HZThis sets the frequency of the RTOS tick interrupt. The supplied value of 1000Hz is useful for
testing the RTOS kernel functionality but is faster than most applications need.
Lowering the frequency will improve efficiency in production applications, but
make the self checks within the comprehensive tests fail.
Note the QEMU model has 8 interrupt priority bits.
The lowest priority on a ARM Cortex-M core is in fact 255 - however, different
ARM Cortex-M microcontroller manufacturers implement a different number of priority bits and supply library
on ST STM32F7 ARM Cortex-M7 microcontrollers, the lowest priority you can specify is in fact 15 - this is defined by the constant
being preemption priority bits, and none as sub priority bits.
The macro
portEND_SWITCHING_ISR() (or
portYIELD_FROM_ISR() can be used to request a context switch from
uses a direct to task notification
to synchronise with a task (not shown), and calls portEND_SWITCHING_ISR
to ensure the interrupt returns directly to the task.
is less than or equal to that set by the
configuration constant (or
configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY).
Set the definition of
configUSE_PREEMPTION within
FreeRTOSConfig.h to 1 to use pre-emption or 0
selected.
Source/Portable/MemMang/heap_4.c is included in the ARM Cortex-M7 demo application project to provide the memory
Please refer to the
Memory Management section of the API documentation for
full information.
Note that
vPortEndScheduler() has not been implemented.
